Fittings on WG
Old Nov 21, 2005 | 12:30 PM
PhatManBUD's Avatar
Fittings on WG
I have the 50mm hks style Wastegate. What do i do about the fittings on top of the waste gate. I have the one that is for the vacuum line to the Boost controller. But i dont have a boost controller yet so do i leave it open or cap it? also theres another opening which looks like its for a 10 mm bolt. Should i just put a 10mm bolt in it?
Old Nov 21, 2005 | 12:41 PM
RotaryResurrection's Avatar
The extra holes at the end can be left open if you want to run base spring pressure. The hole in the center is for a 10mm adjustment bolt that should go to a plate inside that preloads the spring for more base pressure. The other is of course for the boost controller.
Old Nov 21, 2005 | 12:47 PM
PhatManBUD's Avatar
oh okay, thanks for the quick response!
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
