Flooded and need help...did the EGI trick
Old Jan 25, 2002 | 06:54 PM
rxBUN's Avatar
Ok I have a flooded car and tried the EGI trick a few times and that didnt work. Does anyone have the write up for the more complex way (something about pulling plugs?!?!?) that WAS on the www.2ndgenrx7.freeservers.com webiste (the site is down right now and I forgot the instructions).
Old Jan 25, 2002 | 07:01 PM
cymfc3s's Avatar
I Raise Chickens
The EGI fuse not only cuts the fuel, but cuts the SPARK which you dont want to do. You need the pull the fuel pump connector which is located on the driver side rear shock tower. Pull that connector and keep cranking until it starts to fire, then dies. Plug it back in, should fire right up.
Old Jan 25, 2002 | 08:27 PM
rxBUN's Avatar
Nevermind, I fixed it.
tidanb0utch
11
Oct 7, 2015 07:36 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
TrboMike
NE RX-7 Forum
Sep 28, 2015 09:40 PM
Monsterbox
Sep 11, 2015 03:29 PM
