exhaust manifold question
Old Nov 19, 2005 | 06:57 AM
David88vert's Avatar
r71's daddy
My engine came with an extra manifold when I got it. I have a T-78, with a non-divided housing.
The exhaust manifold on the engine is definately a custom job. It is not pretty, and it is not divided, but I do have the wastegate already welded on it. It made good power before with it.
The spare one looks much nicer, and of higher quality. It is divided. It has a diferent wastegate flange, so I assume that I will need a new wastegate for it.
My question: Should I see a benefit of going to the divided manifold, since my tubo housing is not divided?
Old Nov 19, 2005 | 01:30 PM
z8cw's Avatar
Just think about it...
You have individual runners pretty close up to the turbo flange anyways. Than you expand into a common runner or collector that is about twice the diameter a couple of inches before the turbine housing. You lose velocity at this point. With a divided turbine housing and runners your velocity stays up all the way to the turbine wheel. So all you would gain with an individual runner manifold and an undivided housing is a couple of inches before the gases merge at the turbine flange anyways.
CW
Old Nov 19, 2005 | 05:28 PM
r71's daddy
CW
That's what I was thinking, but everyone on here always seems to be raving about divided manifolds, so if there is an advantage - and I have it already - might as well use it. No advantage, then I can go either way.
Old Nov 19, 2005 | 06:25 PM
Crusader_9x's Avatar
If used with a divided turbine housing then its suppose to spool quicker.
Old Nov 26, 2005 | 03:00 PM
dubulup's Avatar
development
If its not divided all the way...there is no way it can help.
Kyo
Apr 13, 2019 09:24 AM
C. Ludwig
Jan 30, 2019 06:31 AM
Engine stand ready
Aug 14, 2015 10:26 PM
