Haltech since I'm going haltech
Old Nov 17, 2005 | 05:59 PM
idsigloo's Avatar
Needs more Displacement.
I won't be able to use my stock BPAV will I? Therefore I'll need an aftermarket BOV, ne1 have pics of where they have their's mounted on the stock intercooler piping with the stock TMIC.
Old Nov 17, 2005 | 06:31 PM
MrRx's Avatar
Rotary on a budget
the haltech has nothing to do with the BOV. The bov is controlled by the boost pressure alone.
Old Nov 17, 2005 | 07:37 PM
idsigloo's Avatar
The BPAV on the TID runs a line to the BAC which is controlled by the ecu, correct?
Old Nov 17, 2005 | 10:15 PM
nik's Avatar
nik
If you're talking about a second gen:
1. The air bypass valve(stock BOV) does not need any computer input. It is not connected to the BAC valve.
2. The haltech can easily run the stock BAC valve.
If you're talking about the ACV (air control valve), its mostly for emissions and not (easily) usable with an aftermarket ECU.
Old Nov 17, 2005 | 10:44 PM
idsigloo's Avatar
I guess I jsut don't know what I'm talking about. Thanks for the input.
I'm used to talking in 2nd gen forum, yes, 89 t2 engine.
Old Nov 17, 2005 | 10:51 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Did he answer your question? The Haltech and the bypass valve have nothing to do with each other, and since also you toss the AFM away too, you dont have to recirculate the air back inside the intake tract.
Old Nov 17, 2005 | 10:58 PM
RETed's Avatar
What's a "BPAV"???
-Ted
Old Nov 18, 2005 | 07:23 AM
20B10AE's Avatar
Gone Darkside
I'm pretty sure he means By-Pass Air Valve, Ted.
Reese
Old Nov 18, 2005 | 09:23 PM
idsigloo's Avatar
I just know there is an electrical connection on the BAC on the UIM. I thought it went to the t2 ecu, but I guess not, I'll get it figured out tomorrow. Thanks for help.
Old Nov 19, 2005 | 12:04 AM
EFI Tech Wannabe
The BAC valve, responsable for Idle control, DOES have a connection to the ECU. The Blow Off / Diverter valve, that goes from the turbo pipe to the pipe after the AFM DOESNT.
The BAC valve on the UIM CAN be controlled by the Haltech.
Old Nov 19, 2005 | 12:35 AM
RETed's Avatar
Hmmm...I need to go dig into the FSM, but I swear there was nothing called a "BPAV"?
I know there's an "Air Bypass Valve" - same thing?
-Ted
Old Dec 19, 2005 | 05:14 PM
miatawheeelie's Avatar
does someone know how to wire up a haltech for a 13b? i have a miata and am switching up to a rotary. just wondering if someone has a list of what wires need what???
Old Dec 19, 2005 | 08:18 PM
idsigloo's Avatar
Haltech.com under downloads has a wiring schematic. hitman.hm has info on that also.
