Sponsored by: CARiD
Reusable Housings?? (Pics)
Old Nov 15, 2005 | 05:59 PM
RX7_ARG's Avatar
Rotary REvolution
Hi people, we´re rebuiding a sa22c and we`ve this housings, they`re reusable?
they have 4mm chrome flaking, this motor was running with good compression but this is what we got now:
Old Nov 15, 2005 | 10:14 PM
peejay's Avatar
Old [Sch|F]ool
Those housings are bad, but they'll "work".
My P-port has housings about that bad, and with all the old seals (all expenses were spared in building the engine) it still does 90psi compression.
Just don't expect much out of the engine. If you want something that will go another 150k miles or so then you will *need* new housings.
Old Nov 15, 2005 | 10:46 PM
R.P.M.'s Avatar
Likes to swear....alot
WOW....I would never use housings that looked like that!!
Old Nov 16, 2005 | 12:12 AM
RotaryResurrection's Avatar
They are certainly worn, as almost ALL 85 and earlier housings will be. IN fact, that is quite mild to what I usually see. It is near impossible to find reuseable rotorhousings for the early engines.
I personally would not build an engine for a customer with those without first explaining like was done above. Even then I wouldn't like it...however, a soft seal like atkins should seal up relatively well after an extended 2000-3000 mile breakin and I feel they could certainly be used. Compression would probably level off around 100 even then. It would make good power but might not be the most reliable and smoothest engine in the world.
Old Nov 16, 2005 | 05:33 AM
-xlr8planet-'s Avatar
I has an emblem
hey dog
I would say "go for it"
in the meantime, save up for new housings.
at least you will have the car running while we figure out if you can build a 13b
Old Nov 16, 2005 | 06:22 AM
Turbo II-FB's Avatar
When I cracked open my 82 12a the were mint except fro the rear had tiny bit of flaking
Old Nov 16, 2005 | 06:24 AM
and take the rough side of a sponge to those housings
