I have a Strange problem
Old Nov 15, 2005 | 01:08 PM
RXILVER7's Avatar
Grabbin My Wankel
OK this is a little weird I have a 1993 and all of a sudden the interior lights stopped working, the taillights stopped working, the signals stopped working, and so did the reverse lights. But the car turns on, and the headlights still work. I checked all the fuses and their all fine, So now I have no idea what to do.
Old Nov 15, 2005 | 01:21 PM
raiden's Avatar
I got a BIG RxTi0N
Talking this might help... :)
https://www.rx7club.com/showthread.p...topped+working
Old Nov 15, 2005 | 02:09 PM
RX 4 Speed's Avatar
1993 VR FD Touring
I would double check your fuses... but that's not really the source of the problem. If you replace that fuse, it'll blow again. You have a short somewhere in your wiring. Did you recently add or tinker around in your interior where there could be wires and such? Same thing happened to me. I had a short with my boost gauge light. I changed tranny bushings and accidentally tightened a bolt onto the wire and stripped it, and causing it to short with the other wire... hope that helps.
MILOS7
Sep 18, 2015 03:39 PM
ChanBagz
Sep 17, 2015 03:36 PM
Monsterbox
Sep 11, 2015 03:29 PM
