problems with 19.5's in the back?
Old Nov 8, 2005 | 04:53 PM
purerx7's Avatar
Registered User
I currently have 18 x 8.5's all around, i have an oppurtunity to pick up the same discontinued wheels in 19 x 9.5 in the back, i would still run the 18 x 8.5 in the front. My first question is, would it look akward with 18's in the front and 19' s in the back? And will it fit, the offset is right here is the size of the tires, 285/35/19. My main reason is to pick up some extra traction in the back, just checking to make sure I can do it first. Thank you for your time.
Old Nov 9, 2005 | 12:31 AM
FD-BOOST's Avatar
FD hunting
I dont know abuot the fitment issue but i think it would look preaty sweet with 18front & 19rear.
Old Nov 9, 2005 | 01:40 AM
rynberg's Avatar
You didn't list an offset. The tires are WAY too tall -- they are a full two-inches taller than stock.... really the only size you could run would be 265/30 19s, assuming the offset is correct. Also, I wouldn't expect an increase in traction with running rubber bands at the rear.
Old Nov 9, 2005 | 01:46 AM
ARD T2's Avatar
Like Ryn said bro, your rear tire is seriously 350z status. Before even answering what is the offset? Is it a +40 or +45. If +45 you can do 275/30, but like rynberg mentioned the tire diameters aren't ideal. I've done staggered diameter setups before.
For this setup your best bet is to run a 245/35/18 front and 275/30/19 rear so at least the sidewalls look to be nearly the same height. What looks gay is when the front tire sidewall looks taller than the rear. So if you stagger wheel diameters on a car that shouldn't have it you will need to use staggered diameter tires so it has some symmetry in sidewall heights.
Rishie
Old Nov 9, 2005 | 04:51 PM
purerx7's Avatar
Registered User
Thanks rishie and to all others who responded, im just going to wait till I can find enkei aegis 18 x 9.5 in the back instead of the 19's.
Queppa
Nov 18, 2024 03:47 AM
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
