Backfiring: Assuming Is B/C I Have A Gutted cat!
Old Jan 24, 2002 | 02:24 PM
rico05's Avatar
WTB S5 N/A FC
Backfiring: Assuming Is B/C I Have A Gutted cat?
Is my logic right on? It never backfired till I gutted my cat. I suspect this would be normal. It is a 91 n/a. Also, would a new o2 sensor help this, as I am buying on along w/ a Hayne's and some brake fluid on saturday!
Old Jan 24, 2002 | 02:43 PM
rico05's Avatar
WTB S5 N/A FC
Any ideas? N/A's run rich, but is that the only culprit?
Old Jan 24, 2002 | 04:59 PM
When I adjusted my air/fuel ratio my car ran and idled much better. No more backfiring!
Old Jan 24, 2002 | 05:54 PM
SpeedRacer's Avatar
Formula Mazda Driver
I'm assuming you mean you adjusted idle/air adjust screw. That only effects your idle mixture, and that screw is only on 86-88 models.
Old Jan 24, 2002 | 06:49 PM
black7's Avatar
Are you sure about the 89+ not having the idle adjust screw on top of the engine? My 89 GXL has one.
Old Jan 24, 2002 | 07:10 PM
SpeedRacer's Avatar
No, that is different. That is just an idle adjust screw on the top of the TB, that allows more air at idle. The screw natedogg is reffering to is on the pressure sensor thing, at it actually adjusts the air/fuel mixture at idle. I didn't mean to say "idle/air adjust screw" in my previous post, I meant to say idle/mixture adjust screw.
Old Jan 24, 2002 | 08:00 PM
Jerk_Racer's Avatar
Is your air pump still online. If so just take the belt off of it. Try this and let us know if that was it.
jerk_racer@hotmail.com
Sethix
Nov 3, 2017 11:48 PM
Andrew7dg
Aug 6, 2017 01:41 PM
Robrods64
Oct 2, 2015 07:56 PM
