Megasquirt 6-port 12x12 VE table
Old Nov 7, 2005 | 11:25 AM
dfwrx7's Avatar
#include <stdhdr.h>
I first 'squirted my GSL-SE back in 2001 using the v1.01 board. Worked great right up until I over-revved my engine one too many times and spun the rear bearing. Now that there's a new engine in the car I've loaded a slightly newer version of the code. MSnS was just being talked about way back when, and MSnS-Extra is what I've got on the car now.
I'm just getting my -SE back to near ready for the dyno. I've got it roughed in on the jack stands but if I can get someone to share a baseline 12x12 VE table with me, that could be a major time saver. Or, if someone can point me to a site/tool that will extrapolate a rough 12x12 table from a 8x8 table that would also save quite a bit of time. Even a rough extrapolation has GOT to be better than the default SBC VE table that's populating most of the table at the moment.
Old Nov 7, 2005 | 11:41 AM
Rex4Life's Avatar
RX-7 Alumni
I think if you import a 8x8 vex file in MT it will interpolate the results to get a 12x12--that should be a big help.
On another related issue--does anyone know of a good ve table editing program? One that could change bins and leave your map the same, and maybe extrapolate bins if you want to go outside your current map. Sure would be handy.
Scott
Old Nov 7, 2005 | 12:12 PM
muythaibxr's Avatar
MegaSquirt Mod
mstweak3000 might do that... but I'm not positive on that.
Old Nov 7, 2005 | 03:21 PM
renns's Avatar
Tim,
As Scott says, new releases of MT should allow importing of 8x8 and automatically generate 12x12 for you. Here's a web-based conversion tool from another MS user:
http://1800philes.com/megasquirt/
Roger.
Coochas
44
Nov 5, 2019 11:08 PM
Microtech
Nov 21, 2015 10:20 AM
edgars95rx7
Link Vi-PEC
Oct 1, 2015 01:59 PM
PinkRacer
43
Oct 1, 2015 09:13 AM
befarrer
Sep 22, 2015 09:33 AM
