Manifold for on-center housing?
Old Nov 5, 2005 | 01:34 PM
4CN Air's Avatar
DETH TRP
What manifolds can be used with a .96 on center turbine housing?
Will the HKS cast work?
Old Nov 5, 2005 | 01:36 PM
RETed's Avatar
FC?
FD?
I know it doesn't work on an FD, cause the turbo ends up hitting the frame rail.
-Ted
Old Nov 5, 2005 | 02:05 PM
4CN Air's Avatar
DETH TRP
yep, FD
I was afraid of that. I did some test fitting with an SSA manifold (hold the boo's), and it hit the frame rail. Looks like I'm gonna have to bite the $200 bullet for a new housing, at least I'll be able to go with divided, and a smaller a/r.
Thanks for the quick reply
Old Nov 6, 2005 | 08:48 AM
APEXL8T's Avatar
boxed in and drawn out
FD is fine.1.00/TO4R
Old Nov 6, 2005 | 11:02 AM
4CN Air's Avatar
DETH TRP
Which manifold is that? Also I'm not aware of any 1.00 on center housings, did you think I just thought it wouldn't fit because of the "large" a/r?
Old Nov 6, 2005 | 05:46 PM
APEXL8T's Avatar
HKS. Another pic.Hope this helps.
Old Nov 6, 2005 | 06:02 PM
MrDirt's Avatar
That is not an on-center housing... it is a tangential.
Old Nov 6, 2005 | 07:32 PM
4CN Air's Avatar
DETH TRP
yeah, i know tangs will fit, with the HKS and the SSA, but on-center is the issue, I'm thinking it's not going to work no matte rhow I try to swing it, I even though about changing the angle of the flange on the SSA but that won't even be enough.
Going to a tang, to make life simpler.
Old Nov 6, 2005 | 07:45 PM
MrDirt's Avatar
That is the best way to do it. On-center housings suck **** anyway.
Old Nov 6, 2005 | 07:46 PM
MrDirt's Avatar
Actually... I have a 1.15 A/R P-trim divided Tang housing if you want.
Old Nov 6, 2005 | 08:54 PM
4CN Air's Avatar
DETH TRP
if I was p-trim my options would be plentiful, unfortunately I'm q-trim (although i believe this will be a good thing once all the parts are bought )
13
Jan 9, 2018 11:19 AM
