How should I plumb my Fuel pump???
Old Nov 2, 2005 | 05:49 PM
rx7onfire's Avatar
Too many toys...
I just picked up an Aeromotive A1000 fuel pump with filter. I need to know the setup for this pump. I have a 87 TII with a 13B-RE motor with the KGParts rails and an Aeromotive FPR. If you have pics that would be great. I basically need to know the setup from the tank to the rails and back. THanks in advance!
Old Nov 2, 2005 | 07:02 PM
MrRx's Avatar
Rotary on a budget
tank -> filter -> A1000 -> Rails -> FPR -> tank return.
Old Nov 2, 2005 | 10:22 PM
rx7onfire's Avatar
Too many toys...
So should I tap into the tank with a fitting, or just come through where the factory pickup is? Also, do I run the rails series or parallel?
Old Nov 2, 2005 | 10:42 PM
MrRx's Avatar
Rotary on a budget
a lot of people have taped into the tank and mounted the pump outside the car, so it would be quiet. Other have mounted it in tank.
it doesnt make a whole lot of difference in how you run the rails, Ive allways does in parallel, but ive seen both ways with no side effects.
Old Nov 3, 2005 | 10:27 AM
rx7onfire's Avatar
Too many toys...
Thanks MrRx, I appreciate the help.
Rotospectre
Mar 28, 2018 03:33 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
