Sponsored by: CARiD
Silicone Vaccume Hose Job??? should i replace this for the oem hoses??
Old Nov 2, 2005 | 01:52 AM
fd3s1128's Avatar
Silicone Vaccume Hose Job,, should I do it???
any suggestion??/ and if yes, where i can get blue Silicone Vaccume Hoses
Old Nov 2, 2005 | 02:11 AM
MrRx's Avatar
Rotary on a budget
If your hoses are old then yes do it.
A lighter helps with removing the old hoses.
http://www.rx7store.net/product_p/hosetech.htm
Old Nov 2, 2005 | 09:57 AM
MrDirt's Avatar
Using some penetrating fluid like PB Blaster will also help loosen them up.
Old Nov 7, 2005 | 07:07 AM
emac's Avatar
i got mine from hosetechniques.com. i used needlenose pliers to get off the hardened rubber hoses. be careful taking them off those emissions solenoid things. they break really easily.
Old Nov 9, 2005 | 10:43 PM
t-von's Avatar
Rotor Head Extreme
Wow that's an expensive kit for a 2nd gen. You don't need that much hose to do the engine. I'm currently using the $15 silicon kit from Autozone. It has 10ft of 4mm thats perfect for my Na S5. It also has 2 other sizes in the kit but I can't remember the size. I like to use a razor blade to cut the old hose and use a flat head screw driver to pry and rotate in the actual cut. This separates the old hose nice and simple without breaking anything.
fd3s1128 Autozone has the blue silicon hose that your looking for. They also have red and yellow.
jza80
Dec 6, 2015 05:53 PM
sYnth.
Aug 19, 2015 06:27 PM
