t45 flange??
Old Nov 1, 2005 | 07:32 AM
turbotommy's Avatar
t45 flange??
is a t45 flange equivalent to a t6 based? thank u
Old Nov 1, 2005 | 09:57 AM
2a+RoN's Avatar
most likely, yes. do you have the dimensions?
Old Nov 1, 2005 | 10:08 AM
turbotommy's Avatar
the a/r on the exhaust housing outer diameter size is 25cm (10 inch) and the turbine exducer is 974mm (3.70") turbine major is 100mm (3.944"). This was the info i recieved about it.
Old Nov 1, 2005 | 11:46 AM
MrDirt's Avatar
Those are dimensions for the turbine housing, but not the flange... You need something like this... this is for a T4 flange.
Old Nov 1, 2005 | 01:55 PM
2a+RoN's Avatar
yeah, the flange dimensions is what I was referring to.
Old Nov 2, 2005 | 09:02 PM
1sgen's Avatar
583 rwhp 1st gen
i had a to4e 60-1 installed , i took it of and installed ta45 on the same manifold . so yes the to4 and ta45 are the same
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
