How to pass emissions with a ported motor?
Old Oct 31, 2005 | 10:13 AM
buzz2's Avatar
I've read many of the emissions related threads, is there a way to get a ported NA motor through emissions?
I run a hose directly from my air pump to the split air pipe on my cat and I use alcohol. I failed a test about a month ago, high HC and CO2. On Friday I had a brand new walker cat installed and failed the test saturday. In fact the HCs were even higher.
Is is possible to run straight alcohol? What is a safe mix?
Thanks,
Buzz
Old Oct 31, 2005 | 10:39 AM
J-Rat's Avatar
Alcohol Fueled!
I would not run straight alcohol, but adding it to your gas is one solution. How big is your porting? A mild street port should not have severe issues with emissions, especially one that has a new cat.
Old Oct 31, 2005 | 12:28 PM
arghx's Avatar
rotorhead
maybe leaning out the idle on an SAFC will help.
Old Oct 31, 2005 | 01:31 PM
buzz2's Avatar
It will idle at 750 rpms. I think it's pretty mild.
Old Oct 31, 2005 | 01:45 PM
J-Rat's Avatar
Alcohol Fueled!
I would agree.
hotshot2014
Jul 18, 2017 02:30 PM
Skeese
65
Mar 28, 2017 03:30 PM
incubuseva
14
Sep 3, 2015 12:37 PM
