hood dampers?
Old Oct 31, 2005 | 08:58 AM
WhoDiddy6's Avatar
Question hood dampers?
looked around and only found FD hood dampers. anyone have any leads?
diddy
Old Oct 31, 2005 | 09:46 AM
MrDirt's Avatar
Why do you need them? Did you get rid of your hood prop?
Old Oct 31, 2005 | 09:47 AM
MrDirt's Avatar
Or are you talking about the hatch?
Old Oct 31, 2005 | 09:58 AM
WhoDiddy6's Avatar
hood prop. tryin to clean it up a tad with the swap i'm doing.
Old Oct 31, 2005 | 10:04 AM
Aaron Cake's Avatar
Engine, Not Motor
No FC came with hood struts.
Fairly easy thing to add though. Probably just use the FD parts since they will be approximately correct, and just add a little angle-iron bracked on the inner fender and hood.
Sounds like a good idea, actaully.
Old Oct 31, 2005 | 11:58 AM
WhoDiddy6's Avatar
i know they didn't come with any, but thought it would be nice to add on... has anyone developed these b4?
diddy
Old Oct 31, 2005 | 12:03 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
never seen one... However... should be easy enough.. just make sure if you use the FD rods that you have an Aluminum, fiberglass or CF hood.. the steel ones will most likely be too heavy.
Else... Just look for the cheapest replacement struts from any other car... even FC hatch struts will work (the hatch is WAY heavier than the hood) BUT.... i'd suggest making sure that they are the type that have no "Lift" on them when they are shut.....
Old Oct 31, 2005 | 12:57 PM
WhoDiddy6's Avatar
it's the tII hood. so it's fine. will check into the FD rods. thx fellas.
Old Oct 31, 2005 | 02:07 PM
Tech_Greek's Avatar
Rockn' The Galant
No, someone's developed them somewhere. I've seen them before specifcally for an FC, it was a major company as well I just don't remember where...
Old Nov 1, 2005 | 12:19 AM
NZConvertible's Avatar
I'm a boost creep...
Hood struts are awesome. Super-easy bonnet opening and no prop in the way when working. My HB Comso had torsion bars to do the same thing and I've often thought about adding gas struts to the hood. Once you had them you miss them!
Old Nov 1, 2005 | 08:13 AM
alwayssideways's Avatar
Nurse I need 1300cc's NOW
ive been talking about doing the same thing in my fc ,, the only thing thats holding me back is time a little money and the bungs you mount the strut to.
Old Nov 1, 2005 | 08:44 PM
WhoDiddy6's Avatar
no foreign countries offer these?
Old Nov 4, 2005 | 12:42 AM
I don't think anyone understands what you're asking. Lots of car all over the world had gas struts for the bonnet, but not the FC.
Old Nov 6, 2005 | 04:18 PM
aderson34's Avatar
Cause i Spit Hot Fire!!
so will the steel hood be to heavy?
Old Nov 6, 2005 | 04:37 PM
jono20's Avatar
like was said above, the hatch is pretty frigggin heavy, heavier than the hood id say. if you used the hatch struts it might work
Old Nov 6, 2005 | 05:00 PM
BoOsTeD Fc3s's Avatar
Newbie
tein makes aftermarket hood dampers. lokar makes sum as well.
Old Jul 9, 2008 | 06:03 AM
joshrulz's Avatar
Fc hood strut kits
http://www.ausrotary.com/viewtopic.php?f=48&t=151267
http://ausrotary.com/viewtopic.php?f...95411#p1895411
http://ausrotary.com/viewtopic.php?f...82667#p1882667
thats the stuff i build
joshrulz
Old Jul 9, 2008 | 07:51 AM
throughthewire's Avatar
Top always down!
Those look great! Have you shipped to the US?
I just bought a new cat, catback, clutch, and transmission doodads, so spending more on the FC will not go over well with the wife for the near future - but I will definitely want a set for my vert!
Old Jul 9, 2008 | 01:11 PM
My5ABaby's Avatar
Rotaries confuse me
Anyone have better pictures of the hood dampers?
Old Oct 6, 2008 | 02:30 AM
joshrulz's Avatar
if anyone wants to email me about the kits i make - nrodpw@internode.on.net
ls1swap
Jun 3, 2024 03:25 PM
