I can get it started, but to get it to idle...
Old Oct 30, 2005 | 03:41 PM
k-rok's Avatar
PHOTOSHOPPER!!
i have to help it, i have to give it slight gas or else is just dies. i DID find that the little white plug that comes off the TB and plugs into the wiring harness, yeah, not plugged in. i THINK this could cause it to not idle at all. mmm what else. oh yeah, to get it started, i have to try to start it up like normal, and it floods. then i cut the power to the fuel pump, and crank the car for like 20 seconds. slowly it acts like it wants to start, then it DOES, probably because thier is so much fuel in it, once it starts i immediatly re-power the fuel pump, and the car stays on, as long as i help it.
note: i havent tried to start it yet with the little white connector plugged in yet, im goin to do that in about 10 minutes.
kthx
K-Rok
Old Oct 30, 2005 | 03:49 PM
ddub's Avatar
i am legendary
You don't even know what that white plug is for and you did a turbo'd n/a? I think you're in over your head here, probably should've left it n/a until you learned more.
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
