wont idle and boggs under load in 5th
Old Oct 30, 2005 | 01:13 PM
TURBORX7II's Avatar
Exclamation Wont Idle And Boggs In 5th Gear
[/B][B]89 turbo II
[COLOR=DarkOrange] timing is off and i have to max out the pickup sender to get it in time but it runs like crap. i have to feather the throttle to get it to move but once im rolling i can make good power. until 5th gear then it boggs. ive checked plugs wires and vacum leaks. its useing and *** load off fuel though. about 8 miles per gallon. its seems to flood the rear rotor. after running it ill look at the spark plugs and the front are clean and the rear are black.
befarrer
Sep 22, 2015 09:33 AM
Donald Hampton
Sep 17, 2015 03:13 PM
teebeekay
Sep 16, 2015 01:54 PM
