Can A B & C weight rotor Be used together?
Old Oct 27, 2005 | 10:57 PM
KSROTARYFAN's Avatar
Can a C and B weight rotor be used together?
Old Oct 27, 2005 | 11:06 PM
Stanello's Avatar
backslash beanbagrace
As they aren't any further than 1 letter away from each other. A B rotor and C rotor? Yes. A B rotor and D rotor?. No
Old Oct 28, 2005 | 11:00 AM
Ok thanks!!
Old Oct 28, 2005 | 11:01 AM
How would I align them? B in front or C?
Old Oct 28, 2005 | 12:40 PM
slpin's Avatar
7th Heaven
align it anyway you want
as you would need to balance it anyways if you want to do it correctly?
Old Oct 28, 2005 | 01:18 PM
Aaron Cake's Avatar
Engine, Not Motor
Doesn't matter. 13B rotors are exactly the same front to rear. However if you know where the rotor came from, you should put it back in the same position to keep the wear on the apex seal grooves constant.
ZacMan
Sep 19, 2015 09:20 PM
Ernstudet22
Sep 14, 2015 09:19 PM
Ian_D
Sep 6, 2015 10:38 PM
