This f****** sucks
Old Oct 27, 2005 | 04:48 PM
cooliomo's Avatar
whats that smell!?
This f****** sucks
replacing my water pump, and i needed to move my omp oil lines and i broke one near the nozzle so what should i do now? also the very thin spacers that r on the engine block when you take off the water pump how many r there one or two?
Old Oct 27, 2005 | 05:02 PM
1SxyRXy's Avatar
my fc broke
you can either A go the mazda and pay 25 bux for a new one or B make them your self, do a search and how to make them there is a full write up. as for the spacers i dont know what your talking about, do you mean washers?
Old Oct 27, 2005 | 05:05 PM
1SxyRXy's Avatar
my fc broke
https://www.rx7club.com/showthread.p...king+omp+lines
Old Oct 27, 2005 | 05:34 PM
cooliomo's Avatar
whats that smell!?
yea washers there very thin
Old Oct 27, 2005 | 05:39 PM
Those sound like they might be the seal gaskets for the ends of the omp feed lines where they connect to the pump or block. They would be made of copper and go on either side of the banjo connector
Old Oct 27, 2005 | 07:44 PM
jediknight7's Avatar
Coolant everywhere!
there is one large washer on the side of the omp pump that is one piece and has holes for all four bolts. on the other side there is a single washer per bolt.
Old Oct 27, 2005 | 07:52 PM
SonicRaT's Avatar
Super Raterhater
If you need a temporary fix, you can take a flat-head screw driver and a hammer, and knock the little clamp off the end of the nozzle (on the engine), and knock off the old plastic (sometimes it doesn't come off with the clamp, that **** gets HARD over time), then you'll see a tiny nipple left over, you can take some small vacuum line, and cut it to size then stick it over the nipple end, then jam the broken end of the line into the vacuum hose, and it should work just fine temporarily until your replacement arrives.
Old Oct 27, 2005 | 07:53 PM
Tessai's Avatar
What will I drive next?
Thing is, temporary fixes have a way with becomming permanent for some...
djSL
The Bad & Fugly Businesses
24
Sep 21, 2017 03:09 AM
alexdimen
20
Oct 23, 2015 01:50 PM
Devon300zx
15
Sep 16, 2015 06:57 AM
