my 79 rx wont start
Old Oct 25, 2005 | 05:54 PM
12a79's Avatar
Exclamation my 79 rx wont start
its been stoped for about a month know dont know what is wrong with it i was thinking maybe ignition relay but cant find it ne where . the engine dosent turn i changed the started and tried them out the starters work but the engine still dosent turn does ne one have ne advise.can it b the coils, or maybe the fly wheel, is it possible that my engine is gone.when i do turn the key all i hear is that relay tap out please help
Old Oct 25, 2005 | 07:52 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
What was it's condition when you parked it. soulds like it may be stuck. Put a socket on the front pully and try to turn the engine. Does the clutch disengage when you press the pettle.
Old Oct 26, 2005 | 09:44 PM
12a79's Avatar
yes the clutch does disengage ill try turning the front pulley 2 see if it works thanx alot for the advise.
Old Oct 26, 2005 | 09:45 PM
12a79's Avatar
Old Oct 26, 2005 | 11:04 PM
aussiesmg's Avatar
Thunder from downunder
Add some Marvel Mystery Fluid through your plug openings before you turn it, it will help free up and clean the chambers and apel seal springs
Old Oct 27, 2005 | 04:01 PM
12a79's Avatar
Old Oct 27, 2005 | 04:29 PM
Hades12's Avatar
Did you try to turn it yet?
Old Oct 29, 2005 | 07:23 AM
Kentetsu's Avatar
6?
Old Oct 29, 2005 | 08:08 PM
ProdigyDevil's Avatar
777777777777777
Old Oct 29, 2005 | 09:13 PM
rotor vs. piston's Avatar
Function > Form
8888~!@@@ Wtf?
Old Oct 29, 2005 | 09:14 PM
kgray's Avatar
GOT WANKEL?
um 9?
so we can all count!
Old Oct 29, 2005 | 09:25 PM
1stgen4life's Avatar
Leaking oil like crazy!
Have you tried roll starting it? That might help determine what kind of problem it is.
Old Oct 29, 2005 | 10:16 PM
SparkienSuggah's Avatar
buzzzzz!-ook!-buzzzzz!
umm, if it IS stuck (carbon locked), won't roll starting it destroy just about everything good inside? I'd stick with the socket-e/s pulley, and if that dont fly, MMO till it does.
12a79:
if the starter goes "click" the battery is bad or the engine is siezed
if the starter goes click whizzzzzzzzz the fly or starter teeth are fubar
if the starter goes click grrrrrrindd the teeth are almost fubar
if you get no noise at all the starter is not functioning... check connections and battery and starting circuit.
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
