Front Brake Caliper Question.
Old Oct 24, 2005 | 03:16 AM
1SWEET7's Avatar
Now With 10th AE Fun!
I want to know where the pad spring goes back in on a single piston caliper. I looked at the FSM and it shows the spring, but doesn't say where to put it. I had brake pads installed about 3 months ago and for the last few weeks I have noticed a squeeling when I brake and also a ticking sound when I drive. I took my rim off today and that pad spring had come unlodged and wedged between the caliper and the rotor. No damage but I took it out and can't find where it goes back on.
Old Oct 24, 2005 | 03:20 AM
maxcooper's Avatar
WWFSMD
There might be some holes in the backing plate (look along the edge after you flip the caliper open). If the spring is a V shape, it probably goes there. It is intended to spread the pads apart.
-Max
Old Oct 24, 2005 | 04:02 PM
1SWEET7's Avatar
Ok I figured it out got it back in there and my brakes work again fine.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
