Which rebuild kit do I get?
Old Oct 23, 2005 | 07:00 PM
rbf41182gt's Avatar
I was planning on rebuilding my 79 12a enigne over the winter with my grandfather, and I was looking at some rebuild kits from atkins rotary- http://www.atkinsrotary.com/store/cu...me.php?cat=590
I was thinking about the overhaul kit A but, does that really have all I need to rebuild? Do I need to replace the apex seals or whatever? The engine has about 130k miles on it and smokes real bad on startup. Also, it's leaking quite a bit of oil in front of the front rotor housing. Overhaul kit B and C seem a bit pricy, do I really need all that stuff, or can I just get the rotor kit?
Can someone help me out? Thanks
Old Oct 23, 2005 | 07:57 PM
Latin270's Avatar
My suggesting is take your motor apart 1st then based on what you see buy what you need.
Old Oct 24, 2005 | 10:37 AM
breesej's Avatar
Amish Gangsta
Make sure that the kit that you buy is 100% Mazda parts. I had issues before with "Viton" oil control ring gaskets. The stock rubber ones are viton coated, and are pliable enough to press in, some 100% Viton ones are too hard and don't want to go in at all, or are not the correct size or shape.
I didn't want to spend the extra money for the stock o-rings, and it wasn't worth the hassle.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
SakeBomb Garage
Oct 9, 2015 10:05 PM
SCinfidel
Sep 8, 2015 05:36 PM
