Properly Jacking Car
Old Sep 17, 2005 | 10:26 AM
IceRain's Avatar
I've never done this before and have a general idea where to jack it up at but would like to be 100% sure so I do not damage anything.
These images have been taken directly from the Haynes Manual. May someone please edit these images and put a circle around to where the floor jack/stands go? thank you very much
Old Sep 17, 2005 | 11:30 AM
Stanello's Avatar
backslash beanbagrace
Some people like to use the pinch welds on the sides of the car, but I like to refrain from using then because I've seen a number of them folded over.
Here's the points I use. Red=Jack, Blue=Jackstands
Attached Thumbnails Properly Jacking Car-untitled2.jpg   Properly Jacking Car-untitled.jpg
Old Sep 17, 2005 | 02:17 PM
tIIsleeper's Avatar
pp
The pinch welds are used ONLY if you are using the jack that came with the car. That is what the slot in the top of the jack is for.
Old Sep 17, 2005 | 02:36 PM
sleejay's Avatar
omae mo na!
i thought the instructions were going to be
'break window, break ignition lock, go"
lol
i never jack from pinch welds. i jack the rear from the differential, and the front from right where it shows on that pic
Old Sep 17, 2005 | 08:53 PM
Snrub's Avatar
Always jack on the front or rear subframe. It's a shame that it isn't stated in the manual or something. The front subframe makes a U shape pointed towards the back. There's ~2" nub on each side towards the end of the U that I put my hydrolic jack on. At the rear there's a circular peice in front of the tire that has a nut at the bottom of it. That's where I jack.
Old Sep 17, 2005 | 10:37 PM
mazdadude's Avatar
this should be put in the archives....
Old Oct 22, 2005 | 12:41 PM
porsche4786's Avatar
I don't see how you can put a jack on the front at that spot, my car is too low, also in the rear when I have my track wheels and tires on i can't get the jack under the gas tank, i bought one of those racing jacks too and it doesn't help, so i made some pieces out of wood
astrum
24
Nov 15, 2017 08:44 AM
cam_7779
Aug 18, 2015 07:48 AM
WLD.RX7
Aug 16, 2015 09:43 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
