How do I pressurize a Single Turbo system? (check for boost leaks)
Old Oct 20, 2005 | 07:48 PM
dhahlen's Avatar
FD Under Construction =P
I am assuming that i just plug up the intake port on the single turbo, and hook up an air pump to one of the nipples and just pump until I reach a desired presure level and see if it leaks? But even if I do that, the air will escape via the exhaust. So I am not sure how I am supposed to do it..
If anyone has any instructions, please throw them my way. I figure there are not many lines to check... so it should be a lot easier.
Thanks
-Darren-
Old Oct 20, 2005 | 07:58 PM
Jason's Avatar
The one
Cap the intake side of the turbo and run a pressure source to the upper manifold or better if you have a nipple on one of the intercooler pipes. Start pressurizing the system and listen for any leaks.
Jason
Old Oct 20, 2005 | 07:59 PM
black beauty's Avatar
the way i did it on my talon when i owned it, was i took the intake off, and put a special coupler on the turbo inlet with a special fitting to accept and air hose, then i would pressurize the system to my desire..usually how much boost i was running and i would spray some soapy water around my couplers and anything else that holds air.
Old Oct 20, 2005 | 08:36 PM
dhahlen's Avatar
yeah i have a nipple on the intercooler piping for boost control =)
Sounds good.
Thanks a lot guys.
-Darren-
Old Oct 20, 2005 | 08:52 PM
LUPE's Avatar
I've got a process that works great but your cheeks will hurt like a **** afterwards.
Old Oct 20, 2005 | 09:00 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Do you think you have a boost leak or something dhahlen or are you just being thorough? I hope that everything is going good for you down there.
Zach
Old Oct 20, 2005 | 10:55 PM
dhahlen's Avatar
Zach
A little bit of both... I am going to take the car to Mazda.... if my engine is blown, I'm probably going to part her out. I don't have the funds to rebuild another engine (that would mean my 4th engine in 2 1/2 years) - that is just ridiculous.
I blew the first one due to old age, the 2nd due to stupidity, the 3rd from lack of a tune (but I haven't been boosting it cause boost doesn't work).
Anyway, I need to find the boost leak, and I also need to make sure it isn't blown. Lets just hope for the best.
Old Oct 20, 2005 | 11:15 PM
2a+RoN's Avatar
i gots a compression tester... hopefully its not blown, didn't you just get that sucker in there??
Old Oct 20, 2005 | 11:16 PM
johnrxt2's Avatar
how many miles on the engine? why do u think its blown
Old Oct 21, 2005 | 12:37 AM
Where did you get the fitting and the white cap? How are they attached?
Thanks
Old Oct 21, 2005 | 12:56 AM
Deusxmachina's Avatar
Thanks
PVC pipe and end cap and PVC cement. Drill a hole in the end and thread in an air compressor fitting. A cheap Home Depot Fernco coupler then connects the PVC to the turbo intake. Those couplers are cheap but will hold the pressure for short periods.
Old Oct 21, 2005 | 01:09 AM
dhahlen's Avatar
My turbo inlet is 4" so its harder to find a cheapass coupler that'll do that. I just need to cap the intake, I have a nipple on the intercooler pipe though.
2A+Ron - Yeah just got it in there.
Johnrxt2 - 17k on engine, crappy *** idle. Won't idle at 900-1000RPM, sounds like it's pinging. Read this thread:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/huge-street-port-wont-idle-right-after-plug-change-473933/
That has my post about the engine problem
Old Oct 21, 2005 | 01:12 AM
dhahlen's Avatar
That's IMPOSSIBLE RHONDA! How can you be asleep and high on crack at the same time?
I'm in Socal... if I were in AZ I'd stop by =/
sherff
Feb 24, 2019 12:09 PM
JZW
20B Forum
Aug 18, 2015 08:56 PM
