Microtech do i need an s5 tps?...
Old Oct 19, 2005 | 04:40 PM
turbo-polak's Avatar
getting microtech LT-8 this week...
do i need an s5 TPS for my s4 13bt?...
ive heard yes and no answers.....
also, if i get just the electronic part, will it connect to my TB?
cheers,Dan.
Old Oct 19, 2005 | 05:57 PM
10sec rx7's Avatar
no you dont need it, s4 work fine
Old Oct 20, 2005 | 03:13 AM
alright, good stuff....
do i need anything else to run the microtech?
thanks,Dan.
Old Oct 25, 2005 | 10:46 AM
snowball's Avatar
I live in the lounge...
your going to want a wideband o2 i just ordered mine from http://wbo2.com/
Old Oct 25, 2005 | 08:18 PM
First gen man's Avatar
yessir
Acually the S-4 TPS isn't very acurate. An S-5 model will make things easyier. The S-4 one likes to uncalibrate for no real reason..
Old Nov 15, 2005 | 02:15 AM
HIMNI Racing's Avatar
Rick James
Ture that ^^
Old Nov 15, 2005 | 09:36 PM
TwistedRotors's Avatar
Compression Tester Guy
This is exactly the trouble I'm having and why I'm working on a bracket to hold a full sweep TPS.
-John
Old Nov 28, 2005 | 10:27 PM
myfc3s's Avatar
That's what she said...
OK? i'm using a S4 Tps, i also have a brand new S5 Tps. The diffrence i see on both is that the S5 have (2) of them. Am i correct? Anyways my question was, Should i use the S5 Tps instead.
Old Dec 6, 2005 | 09:02 AM
SonicRaT's Avatar
Super Raterhater
The sensor isn't the problem. The sensors are pretty much the same thing, they both output ~5v at full open, and ~1v at closed, the only difference is their setup. The S4 TPS guide (or whatever you want to call the metal peice that travels over it) only runs on the TPS for about 25% of the throttle motion before the TPS travels completely out, where-as the S5's guide doesn't drop off as sharp, it moves the TPS out more gradually, and thus it works for a full range. However, since the TPS is just used to help switch between load/idle maps, I really don't see why you'd have a problem using either, the only advantage of swapping to a S5 throttle body would be datalogging accuracy (or trying to retrofit the full range guide onto the S4, there's no need to swap the sensors)
Old Dec 26, 2005 | 01:03 AM
so i need an s5 tps and throttle body? or just one or the other? im getting confused here...
Old Jan 17, 2006 | 09:43 AM
jimmyv13's Avatar
Round&Round not Up&Down
Don'ty worry about it, the S4 TPS is fine. It's not worth going out and buying the S5 TB for it.
Old Jan 17, 2006 | 09:19 PM
already gone, and its on my intake manifold
jim_chung
1st Gen General Discussion
Oct 4, 2015 09:09 AM
nycgps
30
Sep 29, 2015 12:02 AM
