whats up with my car??
Old Jan 22, 2002 | 02:02 PM
jeff_oner's Avatar
i have a 91 n/a with no mods except foam filter/cold air box
the other day i was out driving around and tried to spin my wheels in second, got it up to abuot 7500 rpm in first and dropped it into second and to my surprise, my engine just kind of bogged down. that didnt make me happy, so i tried to power shift it and see what happens, same thing. it revs up fine in first, and when its in second and third it revs up fine also, but its just when i shift that it bogs down. this really confuses me because it just started doing it.
i would just like to know what i can check/play with to remedy this problem.
Old Jan 22, 2002 | 02:20 PM
vaughnc's Avatar
knowledge junkie
So between gears it stumbles (ie shifting into 3rd you get a delay)?
Old Jan 22, 2002 | 02:43 PM
jeff_oner's Avatar
when i shift into the next gear, the engine kind of hesitates, and the rpms, go down lower than where they should, then it revs up, but it doesnt "stab" like it used to (about a week ago). the only thing that i changed that has nothing to do with it, is aboout a week ago i got new tires, i've noticed it since a couple days after that.
Old Jan 22, 2002 | 03:01 PM
jeff_oner's Avatar
can anybody help me out??
im thinking it might be something with the timing, tps, clogged cats.....
anything else i should look at?
Old Jan 22, 2002 | 03:02 PM
vaughnc's Avatar
knowledge junkie
I'll have to check the manual when I get home. Could be the TPS (best bet) or timing but I'm not 100% sure.
Old Jan 22, 2002 | 03:03 PM
rico05's Avatar
WTB S5 N/A FC
Check your dashpot. I had the same problem, and I checked the throttle cable. It was really slack, so I tightened it, and the problem went away!
Old Jan 22, 2002 | 03:09 PM
jeff_oner's Avatar
how tight should the throttle cable be? last time i checked it it was a little loose but not bad. ahould it have no slack at all?
Old Jan 22, 2002 | 04:03 PM
SaabGuy's Avatar
Give it a good tuneup.
Also, what were you doing before?? spinning second?? maybe your clutch is getting weak and cant break the tires loose anymore in second so it kind of grabs slow but doesnt slip?? Does this sound like the problem cause that would bog the engine down.
Old Jan 22, 2002 | 04:13 PM
jeff_oner's Avatar
i think it could be the clutch, because i think it is the origonal one, but could it change that much in just a week?
i used to have a tercel and had a slipping clutch (and bad caburator) and it did kind of the same thing but felt distinctly different than this
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
Junkee
Aug 15, 2015 01:57 PM
