13b and 12a oil pickup
Old Oct 17, 2005 | 03:39 PM
1985GSL's Avatar
Is there a difference? I switched my 85 gsl to 4 port 13b and I lost the 13B oil pickup that goes in the oil pan can i use the 12a one instead? is there a difference thanks
Old Oct 18, 2005 | 03:34 PM
1985GSL's Avatar
anyone?
Old Oct 18, 2005 | 03:59 PM
Jeff20B's Avatar
Lapping = Fapping
Should be the same.
Old Oct 18, 2005 | 04:34 PM
leknaw69's Avatar
Custom SE
Oil picks up
The 74-78 4 port 13Bs had a bigger circunference on the screens, which is great, but late models did not had much of a diference if any...
Old Oct 18, 2005 | 10:32 PM
1985GSL's Avatar
so there should be no problem in using a 12 a one in a 4 port 13b? thanks alot
Old Oct 19, 2005 | 07:33 AM
Siraniko's Avatar
RX for fun
It only matters if you are running a reversed oil pan as in RX-2 13-B transplant. 12-A and 13-B are the same thing except for the screen.
Old Oct 19, 2005 | 01:15 PM
1985GSL's Avatar
but will the smaller screen affect my performance?
Old Oct 19, 2005 | 03:06 PM
Jeff20B's Avatar
Lapping = Fapping
Nope. You're also not really supposed to use a thick oil in a rotary anyway. Take peejay's advice and use a lighter 'weight' oil. I'm in the process of switching from 20w-50 to 10w-30. I think Lynn E. Hannover recommends a lighter oil as well. He described it as having to do with the way the oil is cooled inside the oil cooler.
The1Sun
Mar 18, 2018 11:08 PM
Josh83rx7
Sep 2, 2015 05:57 PM
Cameron38
Aug 19, 2015 06:08 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
