3mm vs 2mm
Old Jan 21, 2002 | 08:04 PM
787B's Avatar
3mm vs 2mm
what makes 3mm apex seals such an advantage?
Old Jan 21, 2002 | 08:08 PM
Node's Avatar
Old Jan 21, 2002 | 08:22 PM
JoeD's Avatar
Originally posted by Node
thats the first usefull post i have seen by you.
good job.
Old Jan 22, 2002 | 02:11 AM
I wish I was driving!
quickly:
On a turbo car, where running lean and detonating is a problem, a single detonation can crack a 2mm apex seal.
Supposedly, a 3mm can take a couple more knocks before it'll crack.
I personally do not think it will make any difference. Its better just to be careful and tune the engine with a wideband.
There are rumours that a 3mm seal will cause more friction and thus less housing life. The claims are that the bigger SA causes this. This isn't true. The only extra friction would come from a larger mass of the apex seals (larger centrifugal force = higher normal force), or if they were of a different material, and I think 2mm and 3mm seals weigh the same.
Got a big turbo car and you're just tuning and you got money to blow? go for it. I'd stick 2mm.
Sean Cathcart
Old Jan 22, 2002 | 02:47 AM
Node's Avatar
good job.
Maybe if you stopped your sarcastic bullshit and actually read posts you'd see some of my other posts.
Get a life.
Old Jan 22, 2002 | 02:52 AM
cymfc3s's Avatar
I Raise Chickens
Stick with the 2mm apex seals. Many racers out there use 2mm seals. If your running lean enough to pop a 2mm, theres a good chance youll blow the 3. I dont believe in hogging out rotors to put a 3mm "band-aid" solution for not having proper fuel management.
96fd3s
38
Apr 19, 2021 06:50 AM
