Power FC Can someone help me with my power FC?
Old Oct 9, 2005 | 06:57 PM
Ranger Yi's Avatar
can someone help me with my power FC?
right now the power FC is between 12 and 13 psi. can someone help me change the power FC setting to a 10-8-10 boost pattern. is anyone in the houston area that can look at my car?
Old Oct 9, 2005 | 07:00 PM
turbodrx7's Avatar
PURIST
I dont think you can just "change" it..you have to have it tuned for that psi, i guess you could turn your boost controller down and then youll just run rich as ****. since i think it will dump enough for for 12 psi instead of you only running 10 psi. Good luck
Old Oct 9, 2005 | 10:19 PM
cewrx7r1's Avatar
Eye In The Sky
Wrong Wrong!
You can change the built in boost controller for different boost levels like reducing it from 12psi to 10 psi. When you run different boost levels (10 vs 12) the PFC like the stock ECU runs diffferent parts of the same map and the AFR should be OK depending on how well it was tuned. It will not go **** rich by doing this unless the fuel map is ****!
Old Oct 9, 2005 | 10:53 PM
rynberg's Avatar
Originally Posted by [url="#"
Ranger[/url] Yi]right now the power FC is between 12 and 13 psi. can someone help me change the power FC setting to a 10-8-10 boost pattern. is anyone in the houston area that can look at my car?
Reread the manual regarding boost settings. You will have to adjust the boost duty cycles to lower the boost. Adjust your target boost levels to what you want to run.
Old Oct 9, 2005 | 11:19 PM
Ranger Yi's Avatar
i dont have the Power FC manual.. i gotta get it still.
Old Oct 9, 2005 | 11:38 PM
reza's Avatar
Maybe he does not have the FC Commander.
Old Oct 10, 2005 | 12:23 AM
snarp's Avatar
Newbie
kahn
Old Oct 10, 2005 | 12:40 AM
rynberg's Avatar
Originally Posted by [url="http:///#"
Ranger[/url] Yi]i dont have the Power FC manual.. i gotta get it still.
You would think you would do that BEFORE posting a question on a simple procedure....or BEFORE installing the PFC, for that matter.
http://www.apexi-usa.com/support_installation.asp
Old Oct 10, 2005 | 12:52 AM
Ranger Yi's Avatar
i do have the commander too
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
