417whp@15 but hurt motor
Old Oct 5, 2005 | 05:09 PM
1wide7's Avatar
i finally dyno tuned my car today at pfs car made 417 and 337 @15 psi but then the motor started running bad ray seems to think a seal is sticking he said we should pull it apart and see before we do any serious damage by turning the boost up
street ported 3mm seal
r-85
850/1600
Old Oct 5, 2005 | 06:41 PM
Comptech's Avatar
That really sucks that something went wrong with the engine. Congrats on the hp.
Old Oct 5, 2005 | 09:24 PM
88fc3sw/HX83's Avatar
Nice #'s!! Was this on a Dynojet, because I made the exact # @ 15 psi on a Dynojet, just using a different turbo.
Old Oct 7, 2005 | 04:35 AM
1wide7's Avatar
yes i was on a dynojet also
Old Oct 7, 2005 | 07:15 AM
CCarlisi's Avatar
Rebreaking things
r-85
850/1600
Nice numbers. Who built the motor?
Old Oct 7, 2005 | 11:28 AM
1wide7's Avatar
rp in manassas built the motor, but ray at pfs is going to pull it apart and see what actually happened
Old Oct 7, 2005 | 03:16 PM
Fd3BOOST's Avatar
Recovering Milkaholic
It's them sneaky 3mm apex seals. I'm telling you.
Old Oct 7, 2005 | 04:24 PM
1wide7's Avatar
thats what ray said
Old Oct 7, 2005 | 05:31 PM
I'm running 3mm 1pc ceramics...no issues here
Old Oct 7, 2005 | 05:48 PM
Fd3BOOST's Avatar
Thats not to say that people can't use 3mm apex seals with out problems. However the factis when yoiu start swapping inards you can run into problems. All in all my opinion is don't fix what is not broke. What you spend in 3m,m apex seals, you coul,d put towards good tuning and be better off then hoping a 1mm difference will save your engine from detonation. Stock 2mm seals can hold up to 30psi from what I have seen, so why bother with the trouble for 1 more mm. when it is ALL in the tuning anyway?
Old Oct 8, 2005 | 01:08 AM
FB II's Avatar
agreed, very well said. and soooo true
Old Oct 8, 2005 | 01:46 AM
racerscreed's Avatar
sweet ride. got pics?
Old Oct 8, 2005 | 03:05 AM
TurboIIGuy's Avatar
Driveline Killer
I couldn't have put it better myself...
I feel that if 3mm apex seals were so good that mazda would have opted at some point in time to use them in the motors as stock equipment.
After all does anyone remember the 6mm apex seals and Dual side seals that came in some of the 12a motors in the RX3 of the 70's???
It was done in an effort to create a longer lasting motor that would hold compression for a longer time........But they didn't stick with that for long....
Old Oct 8, 2005 | 03:48 AM
mwatson184's Avatar
holley guy
3mm seals were used in 12a and 13b motors from 74-85 guy. (at least 74, not up on my rotary history before that point)
You can't' think of it as a 1mm difference, think of it as being 50% thicker, which is definitely significant. I do agree, however, that in general people are trying to bandaid an entirely different problem than seal strength. I also believe that 3mm seals definitely do have their place.
-Marques
Old Oct 8, 2005 | 04:38 AM
1wide7's Avatar
i dont think its an apex seal that went because i drove home 74 miles with no issues it just idles a little rough at times and it lost 20 hp in the high rpms so we will see and as to the tuning comment im pretty sure ray knows how to tune a rotary
Old Oct 8, 2005 | 04:47 AM
Fd3BOOST's Avatar
You could have a spring that is sticking or the seal might be floating at the top end etc.
Either way Ray and them will get you all fixed up. You have that red car with the wide body right?
Old Oct 8, 2005 | 08:08 AM
1wide7's Avatar
yup thats mine
Old Oct 8, 2005 | 08:13 AM
rfreeman27's Avatar
BTW, ive seen stock 2mm seals take way more then 30psi
Old Oct 8, 2005 | 08:22 AM
zinx's Avatar
_________________________
atkins 2mm seals on 54psi down the 1320:
Old Oct 8, 2005 | 09:08 AM
turbodrx7's Avatar
PURIST
Weak...
j/k. Nice numbers, sucks that you messed up your motor. Wait until i get ahold of you
Old Oct 8, 2005 | 03:25 PM
Fd3BOOST's Avatar
Exactly my point. Stock ones are plenty good.
Old Oct 8, 2005 | 09:39 PM
AnthonyNYC's Avatar
Stay tuned...
[QUOTE=zinx]atkins 2mm seals on 54psi down the 1320:
QUOTE]
Whats the fuel system of a car running 54psi look like?
What kinda HP does it make at 54psi?
What ecu are you running?
I've noticed when you blow a motor with the hurley 3mm seals, you can change the seal and back in business. BUT, if you blow a motor with 2mm stock mazda seals...good luck!
Thanks,
Anthony
Old Oct 8, 2005 | 10:17 PM
MrDirt's Avatar
[QUOTE=AnthonyNYC]
QUOTE]I've noticed when you blow a motor with the hurley 3mm seals, you can change the seal and back in business. BUT, if you blow a motor with 2mm stock mazda seals...good luck
That has nothing to do with the size of the seal, but rather the material used. The nature of the seal when it breaks is completely different.
Old Oct 10, 2005 | 03:56 PM
sevenin7's Avatar
Zinx , what kind of seals are these ? Ceramic ?
doritoloco
Sep 5, 2015 12:41 PM
