Microtech Idle lowers under electrical load???
Old Oct 5, 2005 | 12:52 PM
Drift~O-RX7's Avatar
Exclamation Idle lowers under electrical load???
Well I have an S4 TII with S5 manifolds & turbo without any emissions and when tune the ecu and have a good a/f ration (13-13.5) at the desired RPM for my idle my car is fine. Then when my e-fan is turned on or my headlight go on the idle and vaccum drops then I have to re adjust everything but when I turn everyting off the idle goes back up. I upgraded the alternator to an FD so my volts are always at 14. Is there anything I can do about the RPM, Vac drop.
Old Oct 10, 2005 | 07:14 AM
RXdrive's Avatar
I had similar problems. Turned out to be some gounds not grounded properly.
C. Ludwig
Jan 30, 2019 06:31 AM
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
