Microtech which wire goes to FD tach to make it work??
Old Oct 2, 2005 | 11:55 PM
GtoRx7's Avatar
Collections Hold
Here is the question, I would like my tach to work in my FD, I have tried hooking it up to some wires, based off some wiring diagrams. But its not working right. I have a LT-12s w/ 3-rotor, and 6 bosch coils. Thanks for any info. So how do you make the sucker work?
Old Oct 3, 2005 | 09:25 AM
Broken09's Avatar
I am becoming...
check out www.ricemobile.net
If I remember right it's a white wire with blue stripe, but if you look on that website it tells you the stock wiring
Old Oct 3, 2005 | 06:56 PM
fastcarfreak's Avatar
3rd motors a charm I hope
blue wire with white stripes
Old Oct 3, 2005 | 11:27 PM
GtoRx7's Avatar
Collections Hold
I had it hooked up to a blue w/ white, but the tach and speed, jumped all over the place, not accurate at all. Is there only one of these wires going to the dash??
Old Oct 4, 2005 | 04:30 PM
Broken09's Avatar
I am becoming...
You'll find another. I did the same thing. Look on one of the other harnesses.
Old Oct 5, 2005 | 12:55 AM
GtoRx7's Avatar
Collections Hold
I am searching the connectors in the passenger foot well, is this where to find it at?
Old Oct 5, 2005 | 12:32 PM
Broken09's Avatar
I am becoming...
yes
Old Oct 6, 2005 | 11:46 PM
GtoRx7's Avatar
Collections Hold
Cant find another one, only see one. I may be retarded, but I looked at every single wire under there. And only the blue w/ yellow stripe does anything at all. Hmmmmm
Old Oct 7, 2005 | 08:51 AM
Broken09's Avatar
I am becoming...
I'll get off my lazy *** tomorrow and pull my stuff out and tell you.
Professorpeanutrx7
Aug 15, 2015 01:38 PM
Rx7_brad
Aug 15, 2015 09:57 AM
