No spark from trailing coil?
Old Jan 19, 2002 | 05:58 PM
LongBoardLarry's Avatar
My fuel pump cut relay whent out so I put on a jumper and replaced the battery at the same Time, and after that the tach would not work and so I checked the coils with a timing light and no spark from trailing coil. So I replaced the coil and still no spark.
What should I look at next?
Could it have anything to do with the fuel pump cut off relay?
Thanks
Old Jan 19, 2002 | 06:38 PM
peejay's Avatar
Old [Sch|F]ool
All of that points to the trailing ignitor. Without the trailing ignitor working, the ECU doesn't see the engine running, so it doesn't send a signal to the tach and it doesn't turn the fuel pump on.
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
Mps_hell
Sep 19, 2015 10:02 PM
