Sponsored by: CARiD
starts but wont idle
Old Sep 26, 2005 | 10:47 AM
Wforcn1's Avatar
Newbie
Angry starts but wont idle
I have a 1986 2nd gen rx7 that will start and run if you give it gas but if you let off the gas it will choke itself out and die. I put on new plugs and wires. what next?
Old Sep 26, 2005 | 12:36 PM
fcfanatic's Avatar
Escalator now Stairs
AFM is bad? Blown motor? Compression check? Search and troubleshoot.
Need more details.
Old Sep 27, 2005 | 02:23 PM
Wforcn1's Avatar
Newbie
i heard maf are comon for going out on these, is that true
Old Sep 27, 2005 | 07:02 PM
fcfanatic's Avatar
MAF?
Air Flow Meter. Underneath the stock air box. It is a rectangular box with a flap on the front of it to Meter Air flow.
Have you done any troubleshooting?
Old Sep 27, 2005 | 09:20 PM
FirstRotaryExp's Avatar
The Brap is Back
Ive the same problem, though now that ive pulled the P/S and the A/C and turned the adjust screw nearly all the way out on the TB ive managed to get my 88 base to idle at 500 rpm, crappy but at least it will do it now...but i can say with certainty that i need a rebuild in the very near future.
Old Sep 28, 2005 | 03:34 AM
The Ray's Avatar
Check for vacuum leaks,clogged air filter,idle air adjustment and idle set screw.Be sure to browse through an RX-7 service manual before changing any adjustments.
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
