Microtech Engine not responding to adjustments of Idle map
Old Sep 23, 2005 | 05:48 AM
buzz2's Avatar
When I make changes to the Idle map, while the car is idling, nothing happens. I have to make changes to the load map to affect the idle. Is this correct? I have calibrated my TPS.
Old Sep 23, 2005 | 09:55 AM
Aaron Cake's Avatar
Engine, Not Motor
Make SURE that the TPS calibration screen is showing the astrisk. That indicates that the Microtech knows it's at zero.
Old Sep 23, 2005 | 09:50 PM
bob13bt's Avatar
Fixed the wheelhop
How much have you been changing the settings? 1 or 2 whole points will make a big difference on mine (if a certain range is 1.26 for example, making it 2.26 or 3.26 will do SOMETHING)
Also, are you adjusting the cell that the yellow arrow is pointing to?
Old Sep 25, 2005 | 08:43 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
you may have calibrated the tps, but that doesn't mean it returned to zero... just make sure it says 0% tps on your display
Old Sep 28, 2005 | 11:58 AM
buzz2's Avatar
The tps was not calibrated correctly after all. I was changing the wrong value. Once I got this correct I could make changes to the idle. Thanks again for the help.
Old Oct 11, 2005 | 07:57 AM
rxeng's Avatar
Another thing to always look for is the Asterisk on the handset when making an adjustment like this.
The Asterisk will appear when the screen you are in is the one the ECU is looking at.
This will tell you straight away if you are adjusting an active map or not
smikels
Rtek Forum
May 12, 2016 12:34 AM
alphawolff
Nov 17, 2015 05:57 PM
ncds_fc
Aug 15, 2015 10:06 AM
rkhanso
Aug 13, 2015 11:40 AM
