Underbody cleanup
Old Jan 18, 2002 | 03:28 PM
jheaman's Avatar
Underbody cleanup
Is there a best practice for cleaning the underbody? I recently purchased an '84 gslse that has been somewhat neglected. Although the body is fair, the underside is a mess. Flaking debris and rust. What experience have you have in cleaning your baby's belly?
Cheers,
Jay Heaman
Old Jan 18, 2002 | 07:31 PM
genrex's Avatar
Thumbs up Re: Underbody cleanup
[QUOTE] Is there a best practice for cleaning the underbody?.. Flaking debris and rust..
Cleaning the underbody will be a lot of work, but how to get under the car so you have room to work?.. that's a toughie. It will help to pay the $40 or so to have a dealership steam-clean the underbody so it's nice and clean for you to work on.. no mess for you to deal with, and you can see things really well. Then, if you have a good buddy who works at a shop with a car-hoist, maybe you can use the hoist after-hours (for $ or labor or beer) to work on your car. You might talk with a "body shop" to get tips on the actual procedure itself..
Old Jan 18, 2002 | 07:34 PM
JIMMY54's Avatar
GSL-SE PRO
what i did was i cut out the floors of my car and the wheel wells and replaced that all, then sprayed undercoating type stuff all over... It was alot of work but worth it. All this was done on a fork lift that was holding my car high enough to walk under.... Just make sure the car isn't at the edge of the forks and tips over....
Old Jan 18, 2002 | 08:11 PM
genrex's Avatar
If the rust isn't too bad, brush/sand it down and apply some "rust inhibitor" so it doesn't come back, and then apply undercoat paint.
Rescuing a rare classic car isn't easy, but it's worth it.
Old Jan 19, 2002 | 01:10 AM
I went a little crazy with mine,put it on stands and took a wire wheel in a grinder to it to clean the flaky stuff off,then had the under side soda blasted,did any repairs and hosed it with zinc cromate primer before painting it,then I undercoated it,still looks mint! But I don't drive it in the winter,road salt kills cars and ONT. uses 500% more than manitoba ever will.
Old Jan 19, 2002 | 07:21 AM
jheaman's Avatar
Good ideas...thanks for your input!
Jay
ChunkyMonkey
Dec 12, 2005 04:11 PM
357
Dec 22, 2002 05:45 AM
