Power FC Is this a good map? experts please!!
Old Sep 17, 2005 | 05:08 PM
mr.veilsidewankel's Avatar
ONLY FD OWNER IN MY STATE
Hey, just wondering if i safely can make it leaner in the "cruise" area (1800-2500rpm)
anything else you think is wrong(could be better)
Mods are:
power FC(of course)
hks dual intake.
Act Smic
2.5"exhaus without any cats to the catback then 3" all the way out.
veilside evolution catback
performance fuel pressure regulator, a little rased fuel pressure
File Type: zip
Old Sep 17, 2005 | 08:02 PM
Jodeny's Avatar
Indifferent
Its not a good map, there are negative splits and too much high boost timig and inconsitent splits in boost. For your mods you are better off running a stock 5.08 map- it will work much better.
John
Old Sep 17, 2005 | 09:30 PM
hotrodrx7's Avatar
Have you been running with this map? If so, have you checked your AFR's? Besides the problems that Jodeny mentioned, it looks like it would be pretty lean throughout.
Old Sep 17, 2005 | 11:35 PM
hmm, its actually the pfC basemap modded, i rased the fuel from 4500rpm and upp.
started adding fuel from ,7bar, raised 8 then 16 from ,9bar and upp.
how can it be lean? the car smels really rich and uses a helluva lot of gas now
could you modify it to be better and post it?
Old Sep 18, 2005 | 12:27 AM
SlvrRexx's Avatar
wait.... are you saying that you tried to tune without a wideband? ... not a good idea...
Old Sep 18, 2005 | 06:08 AM
hotrodrx7's Avatar
What is your measured fuel pressure? That could be high and the fact that you don't have a cat may be why it smells rich. All I can really say is that my recalc'd base map has mostly higher values than yours and I am near the AFR's I want. I also am running larger secondaries and that would tend to make my base map values lower in those areas.
Old Sep 18, 2005 | 08:57 AM
.. a little embarrased but yes, tuning without wideband,
but we have mapped before with the wideband and my tuner said that the basemap was pretty safe,
and i have added a good amount of fuel to be safe in the hig rev high boost,
or am i wrong?
,think the fuel pressure is about 6-10psi above stock
the car must be rich, shoots flames like crazy, and when its hot it burns out the tail on dovnrev..
but im kinda a noob so i might be wrong, just trying to learn here
and i am going to buy a wideband+exhaust temp gauge this winter,
Old Sep 18, 2005 | 04:18 PM
by the way, dont get any high knock reading with this map (if it matters)
Old Sep 18, 2005 | 09:49 PM
Jodeny's Avatar
Indifferent
thats a version 2 map, not a 508 map which is much better for your application.
John
Old Sep 19, 2005 | 06:32 AM
hotrodrx7's Avatar
You need to check your actual fuel pressure. 6 to 10 psi increase over a stock fuel pressure of 37 psi is a lot.
Old Sep 20, 2005 | 01:52 PM
ok will try to do that. dont remember what the actual pressure was, i didnt install it myself
Old Sep 20, 2005 | 01:53 PM
John
so you think it will work? and be safe?
Old Sep 20, 2005 | 03:54 PM
Jodeny's Avatar
Indifferent
yes definitely.
john
Th0m4s
Feb 26, 2019 02:04 AM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
Microtech
Aug 23, 2015 11:04 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
