NEED PFC MAP stock fuel system with 11psi boost
Old Sep 16, 2005 | 02:50 AM
jimmyrx72002's Avatar
Angry NEED PFC MAP stock fuel system with 11psi boost
i just install T04 small single turbo. And i dont have datalogit software to tune it just yet there is any map just for now that i can drive with 11 or 10 psi of boost.
Right now i have no boost (well 4 psi) and it running very rich and i have no idea what wrong with it. Right after 3000 rpm i have no power at all. I dont know it because of boost control or wastgate or pfc haven't tune or fuel problem any one know please help....and i need steve kan phone # too if any body know please let me have it....
thanks....
t04 turbo
2row inter
avc-r boost control
act clu
PFC ecu
stock fuel system
Old Sep 16, 2005 | 04:59 PM
Talking How much whp with this setup i got?????
stock eng 93 fds
T04 .60 turbo
stanless steel xs manifold
40mm wastgate xs
act clutch
2 row greddy inter
greddy pully
extreme fuel system
1600cc se and stock pr injeters
power fc ecu
avc-r boost control
N1 with straight pipe
Let know if i miss anything could hurt my stock eng 70000 miles. And how much psi is safe the run how much whp i will get.......
Old Sep 16, 2005 | 05:02 PM
Old Sep 17, 2005 | 01:30 AM
SnowmanSteiner's Avatar
Ga-nome liberator
If you're looking for a map you need to try the stand alone section. I wouldn't try to boost if you are untuned. Wait until you can find someone who has tuning experience to look over everything and adjust anything that is needed. It's a lot cheaper than building a new motor.
- Steiner
Old Sep 18, 2005 | 12:35 PM
ErnieT's Avatar
Living life 9 seconds at a time
Putting a single turbo on your 7 with a stock fuel system is plain stupid. Putting it on a tired 70k motor is even more dumb. The turbo upgrade is your last mod, not first.
Old Sep 19, 2005 | 08:37 AM
Jack's Avatar
I see no problem using a To4e with the stock fuel system as long as you plan on keeping the the boost in the 10-11psi range and you have wided band tested your a/f's to confirm you are under 11.5 to 1 to redline. The stock twins move around 46lbs per minute. To4e's move between 36-50lbs per minute based on the trim you choose. It's ALL about cfm..............
Old Sep 19, 2005 | 11:08 PM
well i just got me a extreme fuel system from rx7store hopping that i can run safe with my stock. Well when i say70000k on the eng but it still run good cause my twince stock turbo been messup since i but this new eng on which mean i never race and never rev it to high rpm the eng still smoth and quite hope it will last me till next year..ihihihih
thanks guys
and please dont call me stupid or dumb.. i m new and i dont know anything about single turbo system...=)
Old Sep 20, 2005 | 06:30 AM
ErnieT's Avatar
Never called you dumb, just the idea! Like I said, a single turbo is your last mod, not your first. After you install the fuel system, trailor the car someplace to have it tuned. Don't drive it.
Engine stand ready
Aug 14, 2015 10:26 PM
