Firing Order
Old Sep 10, 2005 | 08:35 AM
JJohnston's Avatar
Firing Order
I cant seem to find any info on firing order for a 90 n/a 13b, I had some wires off yesterday and forgot to mark them, can anyone help?
Old Sep 10, 2005 | 08:49 AM
Tofuball's Avatar
Jesus is the Messiah
The coils are labled and the housings are labled, and in the case you have a distributor, it is labled as well.
T1 goes to the TOP of the front rotor, and T2 goes to the TOP of the rear rotor.
L1 goes to the BOTTOM of the front rotor, and L2 goes to the BOTTOM of the rear rotor.
If you have a CAS instead of a distributor, you can get L1 and L2 mixed up, because they both fire at the same time :p You can also drive without T1 and T2 firing at all. :-p
Old Sep 10, 2005 | 08:50 AM
jl1rx7's Avatar
FLY NAVY
Veteran: Navy
should be t1 top first rotary, t2 to back(with both these on top look for labels on ignitors and housings) followed by l1 and l2 on bottom
Old Sep 10, 2005 | 09:38 AM
JJohnston's Avatar
Perfect, no distributer, coils and they are clearly marked thanks for the help!
Old Sep 10, 2005 | 08:56 PM
NZConvertible's Avatar
I'm a boost creep...
Firing order? Front, rear, front, rear, front, rear, front, rear, front, rear, front, rear...
windom
Sep 11, 2015 04:48 AM
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
