jacking up car...
Old Sep 9, 2005 | 07:46 PM
porsche4786's Avatar
jacking up car...
Where do you jack up your car in the front? When I use a floor jack I end up bending the little thing where they say to jack it up.
Old Sep 9, 2005 | 08:07 PM
Jager's Avatar
Tear you apart
Where the Haynes manual tells me too.
Old Sep 9, 2005 | 08:11 PM
Does the lip on yours get bent?
DC350's Avatar
Rotor Head
Rear diff.... and there is a cross member just behind the front undertray
Old Sep 9, 2005 | 08:35 PM
buttsjim's Avatar
The proper jacking point is under the front crossmember. If you're jacking it up from the side, cut a slot in a square piece of 2x4 to put between the jack and the rocker panel. That way the lip fits into the slot and doesn't get bent.
Old Sep 9, 2005 | 08:38 PM
Innovation's Avatar
He said the front......... Icemark has posted this a couple of hundred times. Check the FAQ and search..................
Old Sep 9, 2005 | 09:18 PM
NZConvertible's Avatar
I'm a boost creep...
Owners manual
Haynes manual
FSM
All cover jacking and support points, and they should be the first place you look for info like this.
Old Jan 19, 2007 | 03:00 PM
fcboy89's Avatar
Originally Posted by NZConvertible
Owners manual
Haynes manual
FSM
yeah dude it shows that u use the side skirt area to jack it up. it doesnt list any other way to do it. only using the stock jack which is ****. it doesnt offer how to do it using a floor jack in the haynes manual.
Old Jan 19, 2007 | 04:57 PM
Beep777's Avatar
How do you get 200+ posts and not know how to jack up a car. I used to gauge the knowledge of a poster by the number of posts he has (don't trust a guy with 3 posts who says it doesn't matter what order the spark plug wires go). Now my world is turned upside down.
Brian
Stanello's Avatar
backslash beanbagrace
From the archives:
https://www.rx7club.com/2nd-gen-archive-72/properly-jacking-car-474970/
Edit: NVM, old thread.
Old Jan 21, 2007 | 07:57 PM
Did you read the FSM like I also suggested?
Old Jan 23, 2007 | 04:46 PM
nathan214's Avatar
beep777 why does it matter if someone only has 3 posts? maybe they know a lot and are new, or they dont get on here a lot or **** like that. i dont think its fair of you to make stupid assumptions
1NSIGHT
Drifting
Sep 29, 2015 12:18 PM
The1Sun
Sep 7, 2015 10:21 PM
