hey guys need some quick help
Old Sep 9, 2005 | 04:34 PM
VaGambler's Avatar
hey guys I have an S 5 car , and I think its a GTU . I have a 88 T rear end Im thinking of switching the the rear ends , but how can I tell if the 90 is poss or not. Need help fast we are here working right now
Thanks in advance
Va
Old Sep 9, 2005 | 05:59 PM
Icemark's Avatar
First.. it would never be a Posi- or Posi traction rear end in a Mazda. Posi-traction rear ends are GM name for a Limited Slip Differential (or LSD here on the board). GM never made a LSD for a Mazda. Calling a Limited Slip Differential a Posi is like calling all refrigerators Kenmores.
2nd A Turbo rear end will be a limited slip rear end, but would require a custom drive shaft and the Turbo Half shafts to work in a non turbo car with a non turbo transmission.
3rd. Unless you have a GTUs (note the small S) model, then you won't have a LSD. The GTUs model will have a tire inflation plate for a 205/55-16 size tire and a aluminum hood, and will not have a factory sunroof.
MoTeC
Sep 10, 2015 07:58 PM
schaft
Time Slips and Dyno
Sep 9, 2015 02:02 PM
Pawes
Aug 20, 2015 07:36 PM
