Very useful modification to stock motor and tranny mounts!!
Old Sep 9, 2005 | 02:14 PM
2Lucky2tha7's Avatar
Back at it again!!
Thumbs up Very useful modification to stock motor and tranny mounts!!
First off, this mod does away with having to buy aftermarket motor mounts and/or using the Racing Beat engine stabilizer brace.
Just thought I'd share a rather useful and cheap modification I've been doing for the past few years on motor and transmission mounts.
Most of the time I find old motor and trans mounts to be separated/ broken. Instead of buying another mount which tends to flex due to the fact that there is only rubber sandwiched between both metal pieces of the mount, I simply modify the existing separated/ broken mounts.
It's quite simple and can be done to un-separated mounts as well:
-On each side of the mount, there is a stud. Grind these off flush.
-Use a center punch to mark the center of where the stud was.
-Using a drill bit that is slightly wider than the old stud, simply drill where you have made the mark with the center punch. (most of the time, the welding that held the old stud in place tends to break away leaving a nice circular hole.)
-Do this for both sides of the mount.
**option 2: for the plate without the rubber, grind off the back side where the welding is and pop out the stud.**
-More than likely, the rubber is still stuck to one side of the mount. You'll need to drill straight through the rubber moving the bit back and forth constantly to eat away at the rubber to make the new bolt slide through more easily.
**IMPORTANT!!: this next step requires the plate without the rubber attached to it to be held onto the rubber side exactly how it was (aka: spin it until it fits where it separated)**
-Once that is done, put the motor mount "assembly" in a vice, line up the holes (eyeball it), and drill straight through the whole assembly to ensure that the new bolt will slide through easily.
-Now go to the parts store and find a pair of bolts that fit the hole on the metal plate ONLY. If I remember correctly, I used either 3" or 4" long bolts. Make sure to buy nuts and lock washers as well for the bolts!! Or you can buy self locking nuts. (the nuts with lock washers will do just fine and have never loosened on me.
-**VERY IMPORTANT STEP** Grease up the bolts and possibly inside of the rubber mount (If the fit is rather tight, re-drill through the rubber to eat away more of the rubber. (USE only 1 size drill bit for the whole mount, don't go larger than the holes on the metal that you have drilled!! It makes for a pain in the *** installation when the mount is "falling apart on you"!!!)
-Now tighten up the mounts to your liking. If the mounts are too tight, you will notice engine vibration inside the car.
-Voila!! You are done!! NO more engine movement!! (well, VERY slightly)
This mod applies to 1st, 2nd, and 3rd gen RX7's
Brian
Old Sep 9, 2005 | 02:53 PM
vaughnc's Avatar
knowledge junkie
Pictures please.
Old Sep 9, 2005 | 03:13 PM
SureShot's Avatar
Seduced by the DARK SIDE
As I see this, you're bolting the mount sandwich together?
Old Sep 9, 2005 | 04:45 PM
Back at it again!!
^yes. Basically, the bolt runs straight through and takes the place of the old studs sticking out either end
Old Oct 4, 2005 | 11:09 PM
renagade_rotary's Avatar
Not a Racist
that defeats the purpose why not just buy solid mounts
Old Oct 4, 2005 | 11:15 PM
rotary downshift's Avatar
althoe i admire the ingenuity of the fabrication it does seem to be a fair bit of work thus i will have to agree with just purchasing solid mounts
Old Oct 4, 2005 | 11:44 PM
GodSquadMandrake's Avatar
Radioactive Rotary Rocket
My only concern would be if this causes engine bucking. Compressed rubber is quite springy.
Old Oct 5, 2005 | 07:38 AM
RETed's Avatar
Stupid idea cause you just eliminate the tension deflection which was part of the original engine mount design.
-Ted
Old Nov 20, 2005 | 06:04 PM
jono20's Avatar
I think one of my motor mountes is broken.... The top metal part has fallen off the rubber part. I'm about to reinstall my engine but then I noticed this. could a mod like this same my mounts? As far as I understand your just running one long bolt through from under the subframe up, through the rubber, through the metal cap, and then it is sandwiched on to the motor mount witha nut?
Old Dec 16, 2005 | 06:03 PM
Back at it again!!
Yes.^
I do agree with the whole engine bucking and that the compressed rubber being springy. It is something that I have to put up with, but I chose to do this at the time because I didn't have the time or money to buy new or aftermarket motor mounts, so I did this instead as a quick "permanent" fix which me cost next to nothing.
Old Dec 16, 2005 | 06:27 PM
misterstyx69's Avatar
Retired Moderator, RIP
read of people using hockey pucks..mor solid than the rubber
Old Dec 16, 2005 | 09:04 PM
philiptompkins's Avatar
i'm always a fan of a little southern engineering i wish i had thought of this before i just payed $40 at the mazda dealer.
