oil filter....ummm...holder...whatever its called
Old Sep 9, 2005 | 11:46 AM
joe3180's Avatar
just a quick question....how do u seal this....i took it off my old motor and i think there was a rubber seal with it....is there 1? and then put black rtv around it to seal this? i think its a pretty important thing to do right...haha
Old Sep 9, 2005 | 11:52 AM
RacerXtreme7's Avatar
NASA geek
Oil filter Pedestal. There is two O-rings under it. Go to hardware store or local Car Parts store and get them. Just using RTV is a bad idea, you don't want to loose oil pressure or oil due to a leak, and it will leak.
~Mike..........
Old Sep 9, 2005 | 02:12 PM
CyborgRyu's Avatar
Drift FC
there's an oil filter ring? i usually just slap on the oil filter after rubbing the edges with oil.....
Old Sep 9, 2005 | 03:47 PM
joe3180's Avatar
but i mean....u do use the rtv around the outer border...dont you?
Old Sep 9, 2005 | 03:55 PM
First gen man's Avatar
yessir
:p He's talking about where the oil pedestal meats the rear end housing. not the oil filter to pedestal.
Old Sep 9, 2005 | 03:56 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
No just the 2 rubber orings under the pedestal.
Old Sep 9, 2005 | 03:58 PM
yessir
just a light coat of RVT with the o rings. Think of it as a gasket/o ring dressing.
Old Sep 9, 2005 | 04:32 PM
Kai's Avatar
Kai
Rotorphile.
Don't do that or it will leak prematurely.
Old Sep 9, 2005 | 10:06 PM
joe3180's Avatar
ok...so no rtv at all? just the o rings? i got sometime before i gotta finish so ill just wait on this till i get a clear anwser. im just confused cuz there was some rtv around the outside border when i took it off.
Old Sep 9, 2005 | 10:31 PM
unek87's Avatar
NA-BOOSTIN
when i got my third fc i was leaking half a quart a day because of those damn o-rings had to go to mazda to get them cause no parts store had the right size $12 for them and i had to wait 3 days to get them . besides that all you need is those o-rings nothing else NO RTV at all or it will leak. put the o-rings in and tighting the hell out of the nuts just make sure they dont get pinched and set right in the grooves and your good to go
Old Sep 9, 2005 | 11:20 PM
joe3180's Avatar
cool...thanks...i knew someone had done it before. i was scared to use the rtv cuz of leaks so i asked if i should..so thank ya
Th0m4s
Feb 26, 2019 02:04 AM
