S4 S5 turbo Transmission mount interchangeable?
Old Sep 8, 2005 | 08:12 PM
Cybaster's Avatar
I think I'm addicted
Hello, are the S4 and S5 transmission crossmember interchangeable?
and is the na ones different than the turbo ones by alot??
thanks
Jonathan
Old Sep 25, 2005 | 04:22 PM
gtrr4's Avatar
I am also curious along these same lines. I want to put my S4 TII tranny and mounts into my S5 TII. Will this work?
Jason
Old Sep 25, 2005 | 08:04 PM
gtrr4's Avatar
So no one has ever tried this before?
Jason
Old Sep 25, 2005 | 08:52 PM
k-rok's Avatar
PHOTOSHOPPER!!
i put an s5 tranny in my s4, bu ti used the mounts that were with the s4:-\
Old Sep 25, 2005 | 10:52 PM
fc3stech's Avatar
From: San Bernardino County, Camp Pendleton, Kissimmee Fl.
I have put a S5 turbo transmission on my S4 turbo II yes it is possible I have done it personally but you need the crossmember of what ever kind of tranny you are putting in so I have a s5 crossmember as well on the tranny, take out the the tac cable gear of the current tranny and put it in the one your swapping and also I dont know any thing of swapping any na tranny's
Old Sep 25, 2005 | 11:31 PM
MrSparkle's Avatar
i'm disrespectful to dirt
s4 needs s4 crossmember and s5 needs s5 crossmember. i found out the hard way...
Old Sep 26, 2005 | 05:08 AM
gtrr4's Avatar
Thank you guys, I needed to know that because my S5 did not come with any of the tranny mounting hardware. Ill just use everything from my S4 then. Thanks again.
Jason
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
