holy shi*t, omp, i hate you
Old Sep 8, 2005 | 10:41 AM
idsigloo's Avatar
Needs more Displacement.
just read a post about how the s5 ecu won't work correctly unless a omp is hooked up to it. is this also true for the s5 t2 ecu? do i need to find a omp!?
Old Sep 8, 2005 | 10:48 AM
lastphaseofthis's Avatar
My job is to blow **** up
you need it plugged in if you remove the omp system, or it will spit codes.
Old Sep 8, 2005 | 11:05 AM
SureShot's Avatar
Seduced by the DARK SIDE
The S5 OMP uses a stepper motor actuator coupled with a position sensor.
The ECU freaks if the position sensor fails to answer or if the stepper shorts or opens.
Old Sep 8, 2005 | 01:20 PM
idsigloo's Avatar
ive already block off the omp spot, can i just hook up an omp and strap it somewhere?
Old Sep 8, 2005 | 01:45 PM
Aaron Cake's Avatar
Engine, Not Motor
Yes. Some people do that. Or just put it back on and avoid the problem...
Old Sep 8, 2005 | 01:48 PM
idsigloo's Avatar
will there be a difference with it bolted to the front cover with it connected to the ecu as opposed to it being held somewhere else connected up?
lets say i bolt it to the front cover, can i just use... 10mm?... bolts to plug the holes?
Andrew7dg
Aug 6, 2017 01:41 PM
nycgps
30
Sep 29, 2015 12:02 AM
