Aux ports
Old Sep 8, 2005 | 12:46 AM
rOt0rHeAd's Avatar
Aux ports
How much force should it take to rotate the sleeve that opens the port? I am suspecting that my aux ports may not be opening so I removed the actuator and tried to turn the lever that the actuator connects to and it felt really gummy. I understand the actuators only need PSI to actuate. So should the lever rotate very easy or should there be a little resistance?
Old Sep 8, 2005 | 12:48 AM
Makenzie71's Avatar
...94% correct.
shouldn't be much resistance...it should turn and return fairly easily. Likely they're gummed up and need cleaning.
Old Sep 8, 2005 | 08:52 AM
johnnyg's Avatar
Hard to say what the limit might be, but when everything's clean, the arm will basically flop back and forth with a flick of the finger (disconnected from the actuator, of course). I'm sure it doesn't have to be like that though, but in most cases if there's a problem, they will stick open, rather than not open at all.
Old Sep 8, 2005 | 10:19 AM
SureShot's Avatar
Seduced by the DARK SIDE
It's usually the shaft seal area that sticks.
A shot of penetrating oil like PB Blaster should free it up.
iamsisyphus
Sep 27, 2015 01:42 PM
frijol
Microtech
Sep 23, 2015 12:51 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
