Questions regarding, starting, stoping, and starting the car again.
Old Sep 7, 2005 | 05:45 PM
mmjb's Avatar
Hey i have an 1988 t2 that i rebuild myself, i'v removed all emissions and have block off plates. I'v removed oil metering pump, and am running remix. I have a problem with starting, stoping, and starting that car again. In the morning after i have let the car sit over night it will start up fine. If i drive it around for a little while, then let it sit so it goes back to normal operating tempture then turn it off, i can restart the car for a few hours or so. Im positive its not flooding, cause i turn the car off by a fuel cut switch. I'm thinking it may be some sensor malfuntioning, but any thoughts on my problem would be very much appreciated.
Old Sep 7, 2005 | 05:59 PM
felixwankel88's Avatar
check your compression
Old Sep 7, 2005 | 06:01 PM
idsigloo's Avatar
Needs more Displacement.
even if you shut it off by the fuel cut switch, might be flooding with coolant. any smoke out the back?
Old Sep 7, 2005 | 06:12 PM
mmjb's Avatar
compression is around 95 or so, its a rebuild with non-resurfaced houseings, and its only got 50 miles or so on it.
and no im not leaking coolant into the combustion area, my spark plugs are dry when i pull them to see if any gas has flooded them.
I think it may be a sensor im missing or not connected. there are a few that i don't have connected. im just not all too sure which and where.
smikels
Rtek Forum
May 12, 2016 12:34 AM
alphawolff
Nov 17, 2015 05:57 PM
josef 91 vert
23
Sep 3, 2015 11:20 AM
smikels
Aug 18, 2015 01:26 PM
