What would be a good Camshaft to put in my engine?
Old Jan 17, 2002 | 08:06 AM
Sniper_X's Avatar
Question What would be a good Camshaft to put in my engine?
Sorry.
I had to do it....
ROFL.
Sniper_X
Always Tinkering
Old Jan 17, 2002 | 08:30 AM
SaabGuy's Avatar
Bullfrog..
Or Spoon
i hear ITR cams are the best
Old Jan 17, 2002 | 09:41 AM
tesla042's Avatar
Make sure you change your timing belt while you're in there.. If it slips, the valves could hit the pistons!!
Old Jan 17, 2002 | 11:20 AM
Thaniel's Avatar
You always have to get a valve job when changing the cam on an Rx-7 or the pistons will fly out. =)
Old Jan 17, 2002 | 11:28 AM
SureShot's Avatar
Seduced by the DARK SIDE
You definately want the unobtanium cam.
Old Jan 17, 2002 | 11:44 AM
DroptopRX7's Avatar
But with the unobtainium cam do I need the maybetainium matched roller rockers?
Old Jan 17, 2002 | 12:01 PM
Josepi's Avatar
Despise Enmity
Can I get ahold of a pushrod 10A motor?
Old Jan 17, 2002 | 01:01 PM
Newbie
This is no joke.... went into autozone about a week ago... thought I'd mess with them...
started looking for parts.. you know.. head gasket etc....
A cam shaft was listed as a part for an rx7 in the computer....
WTF... hahaha
Old Jan 17, 2002 | 01:14 PM
swoop's Avatar
Get the big camshaft with only two lobes.
Old Jan 17, 2002 | 01:17 PM
TonyTurboII's Avatar
Glock Lover
Old Jan 17, 2002 | 01:38 PM
Shamrock1054's Avatar
"Cam with two big lobes"
I work with a girl that looks like that!
Gregg
Old Jan 17, 2002 | 02:15 PM
I have a great cam for you .it will make your car turn 8 second 1/4 times with no other changes,comes with type R decals.All for $30 US.Works great with nawsss Johnny"RICE" Racer
Old Jan 17, 2002 | 02:48 PM
Scott 89t2's Avatar
SOLD THE RX-7!
don't forget to bore out your housings for increased displament too
Old Jan 17, 2002 | 02:55 PM
TwinCam13BT's Avatar
Why wont someone answer the original question?
I would really like to know.
Old Jan 17, 2002 | 03:42 PM
Sniper_X's Avatar
YEA! THANK YOU
Old Jan 17, 2002 | 03:44 PM
Your's in the block or the newer over head cam?
Old Jan 17, 2002 | 03:45 PM
How bout some heads to go with that cam?
Gregg
Old Jan 17, 2002 | 05:38 PM
E6KT2's Avatar
If you go with a lumpy cam you will probably need a new clutch belt. Using a new cam and clutch belt will allow you to optimize your tuning for the full-race muffler bearings!
Old Jan 17, 2002 | 06:15 PM
the krza's Avatar
i didnt know cams had lumps....i hear APC makes the lumpiest cams...and they are clear with red lumps.
E6KT2....have u upgraded to race muffler bearings too? i had to get my tach fluid drained and i had to change BOTH seat cables, it was alot of work i tell yea
Old Jan 17, 2002 | 06:52 PM
Brian P's Avatar
With your new DOHC pushrod converted 10a you'll need to recalibrate your tripple-bypass rotary flangometer.
Old Jan 17, 2002 | 06:57 PM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
dont forget to keep your blinker fluid full. you'll lose major horses if you dont and your water pump will spit flames
Justin
Old Jan 17, 2002 | 09:19 PM
defylogik's Avatar
if you have the newer motor with the variable camshafts id say leave them stock. if you have an older sohc non variable camshaft id say get some crower cams, and aem cam gears. follow that up with bigger injectors to compensate for the lumpy driving and your good to go
happy rotoring!
scott
Old Jan 18, 2002 | 01:33 AM
Don't worry about the cams ,just traded the car for a 10sec. kia
Old Jan 18, 2002 | 06:41 PM
fLyiNgOuFeR's Avatar
LOFL!!!(laugh out ****** loud)
Old Jan 18, 2002 | 07:42 PM
InfiniIIIREX's Avatar
does anyone know if I can swap in the flux capacitor from a DeLorean?
