New O2 Sensor?
Old Jan 16, 2002 | 10:48 PM
Swamp RX-7's Avatar
Question New O2 Sensor?
Hey All. Getting weird readouts with the A/F meter. Sometimes the 7 runs rich at WOT on the freeway, and sometimes it stays with one green led and like 4 orange leds. I'm thinking its the O2 sensor crapping out. Would it do this if the o2 was going bad? What are the symtoms of a bad o2? And if it is indeed a bad o2, whats the best replacement? Any help is welcome. Thanks. By the way, I have a reprogrammed ECU to go along with the mods I have.
Old Jan 16, 2002 | 11:38 PM
dclin's Avatar
Perpetual Project
Re: New O2 Sensor?
Was this happening before, or did I just do this recently? I had my A/F meter modified to read a much better, narrower resolution, during WOT only.
Normal A/F meters are only offer slightly better insight into A/F ratio then none at all, as that (with the wider resolution) the diffence between running lean or rich can be hard to tell.
See: http://gadgetseller.com/gauges/
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
