Replacement Coil
Old Jan 16, 2002 | 10:21 PM
LongBoardLarry's Avatar
Replacement Coil
I have a bad coil on my 85 GS.
I called to get a replacement and the guy told me it had to be the same make as the current one.
That doesn't sound right to me.
What is the best coil for a good price?
Thanks
Old Jan 17, 2002 | 04:46 AM
yayarx7's Avatar
Are you Nucking Futs?
if I am not mistaken almost any aftermarket coil will work. If I were poor I would get one out of a junkyard. If not upgrade to two from the local speed shop.
Just my $.02
Old Jan 17, 2002 | 09:30 AM
Siraniko's Avatar
RX for fun
if u have the stock ignition, just buy the msd coil for non-msd ignition. they cost appx $35/each.
Old Jan 17, 2002 | 09:39 AM
WackyRotary's Avatar
standard combustion
I've heard stock coils are around 30KV. What would a replacement
MSD coil(blaster coil, I presume) that is Non-MSD igition be?
Old Jan 19, 2002 | 01:24 AM
Not 100% positive but seem to recall the figure of 45 KV listed for that coil setup but they do put out more KV at lower r.p.m. which helped pick up low rpm torqe on my car.
Old Jan 19, 2002 | 02:11 AM
gamble302's Avatar
roadkill hats rock
wheres kv listed? i got a couple stockers outta the jy so i can do the dlifdis setup in the future. as a matter of fact theyre sitting here on my desk collecting dust, nice paperweights though. i paid 8 bucks a pop for em at the junk yard. anyways all they say is daimond lb-84 12v 2x25 as you can see from the pic i just took. whats does all that mean?
Old Jan 20, 2002 | 06:32 PM
standard combustion
Whats a dead giveaway for a failing coil. OR one that is providing weak spark? I have the weirdest starting problem in my engine right now:
Starts right up when cold. Starts harder then a Motha-F#cker when its turned off warm and you try to start it with in 5seconds of turning it off-10minutes later.
It usually takes a near-flooring while turning the key to start getting some igition when it does this to start it.
This is a very cold climate too: 0-20F range right now. It never has done this in the past either. .I've ruled out all the obvious problems a while ago. No, the Plugs are not fowled or it would start hard all the time. What are syptoms of ignitors not working very good?
Old Jan 20, 2002 | 06:56 PM
standard combustion
Would a bad ignitor do it? Hard starting right? But, how come it starts hard only when warm?! Just after turning it off up to 10minutes its very hard to start only.
Old Jan 20, 2002 | 07:58 PM
guru's Avatar
Coil tech
Hey man,
coils do tend to show there weakness once hot, I recall reading something about greater resistance when warm, regardless. Get an ohm meter let the car get warm then refer to your trusty haynes manual for resistance measurements for your primary and secondary windings, all the 411 is in the book. Takes about 10mins to check. Most coil failures or weaknesses will show themselves at hig rpm also, so try shifting high at full throttle and look for hesitation, shuddering, etc.. ciao
guru
Old Jan 20, 2002 | 08:04 PM
rxseven's Avatar
Special Dark
Re: Replacement Coil
Thanks
Hey, check your PM
Old Jan 21, 2002 | 06:52 PM
Well I have replaced the Coil and igniter and still no spark from the trailing coil.
What should I look at next?
Old Jan 21, 2002 | 07:07 PM
standard combustion
I check the connections to the coil to see if the wires have opens in them somewhere maybe?
Old Jan 21, 2002 | 07:23 PM
I checked all the connections and wires that I can see.
I am stumped.
Is there a fuse that goes to the coil that isn't in the fuse panel?
zuesskroph
Aug 13, 2015 06:05 PM
